RB25DET TPS Sensor
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
Good Morning Everyone,
I'm posting this because my friend has had his RB25DET S2 for quite awhile and sadly it has never ran 100% since he did the swap. He has tested different sensor and what not and right now he is on to testing and setting his TPS. Sadly, again, all the information I have read on here and all the other websites/forums for setting the TPS do NOT follow the RB25DET FSM at all. Everyone is setting the TPS (a variable potentiometer) using volts. This is INCORRECT. So here are two screenshots straight from the FSM to hopefully clear up the information that is out there as of now.
THROTTLE SENSOR SYSTEM (SELF-DIAGNOSIS DISPLAY 43)
COMPONENT PARTS INSPECTION
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Isn't the first step check the voltage at WOT and closed. looks like it says if you have atleast a 3.0v difference its ok.
sjbsuperman1425
CA18DET
The voltages in the first picture should be a result shown in the data monitoring mode from the TPS being set to the resistance specs under component parts inspection.
Ben240sx
Car: '95 240sx
awd BNR32 GTR swap
well, im just puttin in my two cents, i just did the TPS setting by the voltage on my BNR32 swap and its never ran better.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Are you talking about measuring resistance within the TPS with it unplugged vs. measuring voltage with it plugged in?
When the ECU is ON, the output from the TPS to the ECU should be just above 0V closed and <5V WOT like the FSM says.
