Its an aeromotive, I wish i had some smaller pics to post up, i have some pretty good ones.Darius wrote:What a bruiser! Nice work.
btw what FPR is that?
If you host the pics on nico it will give you 2 diffrent sizes. works great for my pics.SillyRB wrote:
I am still going to be parting it out very soon, but thought i would post some pics while it still belongs to me.
I will try and get a dyno graph / and or video up. With some cams and more boost i say it would make approx ~650ish.
It is a custom fuel rail, i had a local guy make it for me. Changed the injector feed to a top feed set up. Also make it Dual Feedscottsi wrote:what feul rail are you using? i like that setup, so you can use top feed injectors. id like to run somethihng like that aswell, care to share any info?
Have you thought in all honesty what the chance of a rock bouncing around in your engine bay, and some how dramatically finding its way into the turbo is ? I would say next to NONE. If i am ever driving far i will put a intake on it, i have a 4" intake that i made, it uses a 4" K & N Air Filter. I went to the tracka few weeks ago, the car went 6.8x @ 105.x in the 1/8 mile.Darius wrote:norikumiin- There aren't too many rocks bouncing around in the engine bay and even if there were, it would take a miraculous bounce to enter the turbo. Sand and grit could get sucked in as well, but it won't KILL the turbo. If run for a long period of time (months) without a filter, you might run the risk of having excessive wear on the compressor housing and/or impeller.
ehacker01- HKS makes a 100mm suction funnel for $~$115 on nengun.com. 100mm isn't quite 4in, but 3.937in is pretty close. It's anodized purple too for all you limp-wristed types
$110 is a little much. I found some from some guy in australia for $55 but then shipping would almost make the difference. If anybody comes across one let me know.Darius wrote:ehacker01- HKS makes a 100mm suction funnel for $~$115 on nengun.com. 100mm isn't quite 4in, but 3.937in is pretty close. It's anodized purple too for all you limp-wristed types
