240sxed »
https://forums.nicoclub.com/240sxed-u28683.html
Mon May 30, 2005 11:04 am
Ok ok... So the fuel pump relay works, i hear the fuel pump prime.
Now, I know I am NOT getting spark, but the little ecu light is on when the key is on power.
I connected Pin #1 on m63 harness to pin #45 on the ecu (these are both black/red thicker gauge wires)
f2 (ka eccs relay)#2 red/black to R33 ECU pin #16
#3 black/white to r33 ecu pin #49 (the guide that im using says after that, 109,59 , cas, afm-eccs relay power out put)
#1, #5? both red wires, connected that to ecu backup pin #58 on r33 ecu?
what am i doing wrong, am i missing an ignition wire? can someone help me with the difference between ecu relay, ecu backup power, ecu power?
Anything to help with the ignition/eccs wiring would be appreciated, or if theres any other reason why I wouldn't be gettin spark... I kept the ignitor chip out untill i test it to avoid blow it.
