rb25det to 300zx z32 oxygen sensor wireing q's
captainclutchkick
Car: 1990 nissan 240sx coupe with rb25det
ok heres the deal my rb25det oxygen sensor is wasted and i got a 300zx z32 02 sensor from a freind and the pigtail connector plugs into the rb harness ok but the wire colors are different than the rb 02 sensor i removed. the rb sensor has a white wire on the left a black in the center and a white on the right, the 300zx sensor has a black on the left a white in the center and a red on the right. how do i need to wire this to get it to work on my rb25det series 2 engine?
this is the rb25det 02 sensor pig tail ^this is the 300zx 02 sensor pigtail ^this is the 300zx 02 sensor plugged into the rb25 02 harness connector, will this work or do i have to rearange the 300zx wires to make this work like the rb25 02 sensor since the wire colors are different?
rb25 gurus please help a bro out im retarded and need some guidence!
minivan_don
although i have no experiece with this perticular mod ... i would probably follow the way the wires fit in the harness and the harness will only fit in 1 way.
if your really keen, why not just install the z32 o2 and see if you get an cel or it runs funny... if it does, kill the ignition immediatly.
captainclutchkick
cmon guys i need some info
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
do us a favor and go look it up in the FSM for both cars.
See what you come back with and report it.
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi
and then look at the RB wiring diagram... have at it champ.
jrb92se
Car: 1989 Nissan S13 coupe
why cant anyone just answer his question, he bought a z-32 o2 sensor that is supposed to work with the rb, is it plug and play or does it need to be rewired?
NightKids2
Just keep trying different connections until your car doesn't run like shat.
I know thats a stupid idea, but thats what I did lol didn't take 10 minutes to figure it out.
gawdzilla
Car: none
here's a hint. you only need to have one wire correct for it to work.
Carl H
or dont make it complex and go buy an o2 sensor for an 1984 200sx turbo...generaly speaking on nissan 3 wire sensors the middle wire is signal, if in doubt take a multimeter and find out which 2 have continuity, thats the heater circut.
