RB25DET Timing?
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Stock is sopposed to be 15* right? I heard its OK to advanced it 5* more. Any truth to this?
Joe
5 is pushing it.
without a wideband there is no way to know how far you can safely advance it. leave it stock unless you can monitor your AFR's.
DrifterProdigy85
Didnt think Timing changes AFR. It didnt with my SR. I know when ever they tell you to tune a standalone, to tune the AFR first then the timing. If anything I guess youd need a knock meter for the timing.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
That is wrong, timing always effects the AFR's. Timing is part of the tuning process.
Joe
DrifterProdigy85 wrote:Didnt think Timing changes AFR. It didnt with my SR. I know when ever they tell you to tune a standalone, to tune the AFR first then the timing. If anything I guess youd need a knock meter for the timing.
lol timing is a HUGE part of your afr.
if you are trying to take AF readings off your stock o2 sensor, DONT. you need a WIDEBAND.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
+1. Since my timing was far too advaned on my SR and it ended up knocking at high rpm and boost which lead to ringland failure.
Same with a friend of mine on his KA-T when we hooked up a wideband to it, having the timing advanced he had AFR's all messed up.
DrifterProdigy85
Yea i follow you. My SR always ran 11.5 AFR using the Innovate LM1, even when i increased timing from 15-20* on that it read the same AFR but my SAFC started picking up knock from it so i turned it back to 15*. Ill leave the RB alone. Ive got a AEM Uego on that but doesnt read accurate due to bad exhaust leaks at the turbo elbow. Always shows lean even though its running rich enough to smell the hint of gas at the exhaust leak.
