NYCRB240sx wrote:mckinny motormounts, mckinney downpipe, mckinney one peice driveshaft, jon powell for the wiring job and your set, other then that get yourself some perma cool fans, intercooler, koyo radiator, new gasket set, new water pump, new timing belt, custom intercooler piping made, and you can run it
and if you dont wanna spend the 1200$ for the expensive mckinney stuff you can use the r33 crossmember, have a driveshaft and downpipe made locally and that should total you under 500$.
also doing the wiring yourself is not hard. just requires some intelligence and wiring diagrams.
and you dont NEED a radiator or FMIC.
i would definatley reccomend a new timing belt and water pump tho.
