rb25det swap s13
maickS13
hello, my name is Michael and I'm from chile a have the 200sx of `91, now I'm doing a swap in order to do drifting, as the ca18det was merged, I hope you enjoy the pictures, sorry if my English is not very good.
well, complete disarmament engine, to revise it and was again recorded as valves and buying gaskets kit, and now I'm making the supports of the box and engine.
Modified by maickS13 at 12:33 PM 10/15/2008
Modified by maickS13 at 7:30 PM 10/21/2008
Carl H
cool deal man and welcome to nico.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Recepción a Sr. Aragon del Nico.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
welcome to NICO, swap looks like it's heading in the right direction.
maickS13
some things that I have and I have to install in the car.
thanks for the welcome, counting them more or less like I'm going to do all this: I now have-boost gauge blitz -timing belt greddy -exhaust obx racing -manual boost controller -turbo timer HKS-kit gaskets rb25det -tachometer with 3 gauge inside -radiator wiht fans 12" and silicone hoseExhaust-line 3 " stainless steel and some things that come later.
Modified by maickS13 at 7:33 PM 10/21/2008
maickS13
is there anyone who can help me with the wiring connections, because I have a dvd repair but I understand 60% of what they speak (in English), I speak Spanish and little English but not enough to understand everything. someone help me with as fix the wiring, I like 2 plugs cut, where the ground was already going, but the others do not
maickS13
fix the pictures, and here I put some things that I purchased
maickS13
Kalypso
oh! YEAH
maickS13
I have really time to devote to the car is very little, but it is almost ready, and missing the final details
BoostFab
Car: S13cp, S13fb, S14z
the result is near; keep it up....
Sil240
Car: Nissan S13 "The One Cam Wonder"
Welcome to NICO,
Great work!!!
Checkout SFLdrifters.com or SFL240sx.comThey are Miami based sites so 85% of the people speak spanish.
maickS13
ya q hace rato q no pongo ningun avance ahora es cuando, tengo algo mas desde la ultima vez q puse una foto, espero ya terminar luego me ha dado lumbago como unas 4 veces desde q empece a webiar con el motor, me cortado los deods no cuantas veces y cortes brigidos, eh consumido bencina por los ojos, refrigerante por las orejas, y aceite y tierra por todos los poros jajajajaj, pero ya va bien encaminado.
while that does not get any progress, now is when I have something else since the last time you got a photo. I hope to complete course has given me as lumbago about 4 times since I started to install the motor, I cut the fingers are not as often and big cuts, I have gasoline consumed by the eyes, ears by coolant, and oil and land for all jajajajaj pores, but it is on track.
preparando la empaquetadura con aceite para el ensamble
1º apriete suavesito nomas
aqui esta el culpable de q me va a dar como 6km/lt
aviso esas fotos fueron sacadas con el telefono
notice these pictures were taken with the phone
jdmforever
Car: nissan s13
ey como va el rb se mira bien sigue informando de como va todo adios
maickS13
cada vez queda menos para terminarlo, ya tengo instalados los 2 multiples, el turbo y sus cañerias, lo q falta es poner a punto, instalar el cableado, instalar el embrague q deberia haber llegado el viernes la caga y todavia no esta en mi casa, darle apriete a la culata, recolocar la linea de escape que quedocorrida por unos milimetros(pense q iba a tener la cuea del mundo al quedar justo donde estaba la otra, pero quedo un poquitito corrida), instalar mangueras varias y seria, ojala no aparezca algun maldito imprevisto, espero poner la foto final del motor armado enterito y despues un video del 1º encendido.
is increasingly less to finish it, I already have installed the mainfold and exhaust, and the turbo pipe, what is lacking is to the distribution, install the wiring, install the clutch that should have arrived on Friday, (for the ****!!!!!) and still not in my house, give it to tighten the cylinder head, reposition the line exhaust system run by staying a few millimeters (I thought I was going to have the fate of the world to be right where he was the other, but am a little run), install Several hoses, I hope not appear any unforeseen damn, I hope to put the final photo of the entire armed engine and then a video of 1º start.
jbotch79
Car: '90 240sx RB25DET series 2 swap
'97 Audi K04'd 1.8T - DD
nice job so far. I am hoping to do the same swap soon. Where did u buy ur rb25 from??
maickS13
I will buy in Iquique, a port city (franca zone) in northern chile, which comes from all JDM, cars and motors imported from japan
