chachi longshot »
https://forums.nicoclub.com/chachi-longshot-u6821.html
Mon May 05, 2003 5:46 pm
You have to use the RB25 transmission. I believe teh internals of the transmission my be the same, but the housing is different and won't bolt up.
I'm pretty sure you can use the stock mounts and R33 crossmember to mount the engine, but you will have to make a cut in the hood to make it fit, just the inside skeleton of the hood.
I'm going to be putting a RB25 in a s14 as well. I'm still debating which route to go with the mounts. Mack, if you use your custom mounts do you also need to use a downpipe made by you guys? And how much is the mounts/dp etc? Your site was messed up so I couldn't get anything.
