RB25det swap now running.
Zkyline
Car: 300zx. Rb25det swap
If anyone is interested in how to splice an RB25 (s2) harness into an early z32 (8bit) harness. I have a good start..still working out cold start sensor and a few others.. but she fired up without hesitation! Still no intake or coolant pipes plumbed, so considering that, she runs ok! Link to youtube vid: http://youtu.be/aGQNK693SOI
I will do a writeup on the wiring once I get it running decent lol.
Also motor mount xmember ect if anyone is interested
Zkyline
Like I said. No plumbing yet. Engine not getting metered air through maf. Maf is sitting on lower rad support lol. So all things considered im pleased.
DCaff300ZX
Car: .
1993 CRP TT- Modified
Hmmmm, interesting...keep us posted! :bigthumb:
Zkyline
Ive narrowed down the stumbling/sputtering issue to it only running on 5 lol. It has good spark from all 6 coils. Injector to #2 cyl not working.
Checked mechanically, by pressurizing and hooking ground and power to it, it sprays fine, same as #1. Checked resistance and #1+#2 are both 12ohm. From what ive read it should be from 11.4-14? So that seems fine.
Double checked my wiring with power probe. Wiring good from ecu pin 110 to injector #2. So short of a break in the solder on circuit board in ecu, or CAS not giving signal to #2? Anyone with experience on this id appreciate it! Thanks guys.
Zkyline
In testing the CAS I found everything was fine, but I noticed all the injectors were firing in a row, 1-6. Its because I followed someone elses WRONG info on using a z32 ecu, and rewiring to suit. So if anyone is curious it needs to be 1-1, 2-5, 3-3, 4-6, 5-2, 6-4. (RB25-Z32) same goes for coils. Fired up, runs on all 6 now.
Ziggy1621
Car: '90 Z32 TT (Shibui)
'90 Z32 2+0 NA
'68 311 Roadster
2004 Rx330
2011 BMW 550i (TT)
Sweet! post up a vid brutha!
Zkyline
https://youtu.be/n5Wr8gCJBZ4
Ok you twisted my arm!
MrFeesLaw
Car: 1993 300zx 2+2
Congrats on finishing the swap. Just starting my Z build this week. Hope it goes as well as yours seems to be going lol.
Zkyline
About 6 months from when I bought it till now, im pleased! Basically just bodywork and paint from here
DCaff300ZX
Car: .
Nice, but I can't see what you've done in front for the fan and rad and also other front stuff...front e-fan ???
Zkyline
