So the rb starts up and all, got everything pretty much wired up. But when I drive the thing, it doesn't feel like theres a whole lot of power or pull to it? it infact feels weaker than a SR or KA-T. Well im assuming its because i've got something done wrong.
Somehow I managed to hookup the intercooler the wrong way, the cold pipe is switched with the hot pipe end. I just looked at an FSM and realized i had it on backwards. Would it make a diff though? I was thinking it wouldn't because its just fins right? Well let me know if this is it?
Im trying to think of anything else thats wrong, I don't hear any vacume leaks but I may have some, my boost gauge reads -.50 and pretty much stays there constant. But when I rev(or let go of the throttle), I die out sometimes. I am NOT using an aftermarket bov either.
I have the maf hooked up and so forth, but there is no metal spring in that rubber inlet hose that goes to the turbo. I know on SR's that pipe needs the metal inside or else it collapses under boost? It doesn't seem to be havin that effect where it bogs at higher revs though. The thing boosts about .5 bar according to my profec b which is just reading boost, not being used as a boost controller. Any ideas?
Heres a link to my sorta writeup
http://www.speeddreamz.net
