RB25DET starter
s13point5
Car: 89 240sx
im looking for a starter (working or not) for my RB25DET. my motor was originally a automatic but between japan and my garage, someone stuck a 5speed transmission on it and didnt supply me a starter. is there a USDM starter that will work? does anyone know where i can get one? or is anyone on here selling one?
otis
Car: 93 mazda Rx7 R1
http://www.napaonline.com/Mast...ndard
this is a link which i got from a thread a while ago when i was searching for starter info and i kept it just incase my starter ever went out. i am NOT 100% sure of this starter but, this is what someone on here said we could use for the rb25 motor. someone correct me if this info is wrong please.
s13point5
Car: 89 240sx
otis wrote:http://www.napaonline.com/Mast...ndard
can anyone confirm this?
otis
here is another link that i found from freshalloyforums that lists a bunch of part numbers for skylines. i suppose they are in conjuction with the nissan company itself.
showthread.php?t=162633
s13point5
Car: 89 240sx
otis wrote:here is another link that i found from freshalloyforums that lists a bunch of part numbers for skylines. i suppose they are in conjuction with the nissan company itself.
that link doesnt work
otis
ok, i don't know what is wrong with that link. it keeps going to nicoclub for some reason..... go to forums.nicoclub.com and then go to Skyline gt-r/gt-s link and it will have a sticky in there with part numbers.
s13point5
Car: 89 240sx
otis wrote:ok, i don't know what is wrong with that link. it keeps going to nicoclub for some reason..... go to forums.nicoclub.com and then go to Skyline gt-r/gt-s link and it will have a sticky in there with part numbers.
oh ive seen that thread before. i guess the part number for my starter is 23300-20P05. but im not quite sure what im suppose to do with the part number. because i know i cant just go to nissan and have them bring up that part number for me
BigPar
there was a thread recently where someone used a part from an older nissan that you can get brnad new from napa and such. I'll see if I can find the part number or link later when i get home from work.
lilskyline240
Car: 90 240sx w/ rb30det
i got a spare starter. not sure if i want to part with it tho...
s13point5
Car: 89 240sx
BigPar wrote:there was a thread recently where someone used a part from an older nissan that you can get brnad new from napa and such. I'll see if I can find the part number or link later when i get home from work.
lilskyline240 wrote:i got a spare starter. not sure if i want to part with it tho...
part with it
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
To use the part # you have (23300-20P05) you need somone who has FAST and can pull up the part # for you. 99% sure your local Nissan shop does not have it. I know of a few places who CAN get Nissan JDM parts, but it would take over a month to get them here :-\
What is the starter from NAPA off of any way? I'm considering pulling mine to see what it would cross with here Stateside..
otis
if you can, let us know who can get those nissan jdm parts. i would like to know, just incase....
s13point5
Car: 89 240sx
bump.... come on guys. this is one of the very few last things i need for my car to get it drivable. hook me up!
bmadd2402
Car: Twin Turbo-shaft UH-60L, 1992 RB-240sx
call shea at nismoparts.com. he'll get you squared away.
Racinjitter
Car: 1988 300ZX RB25DET
1988 300ZX Shiro Special
The napa part number that is confirmed to work on a RB25det is 2444514. Link to hybridz thread with pictures on the second page. http://forums.hybridz.org/show...arter
Lets just say anyone paying more than $30 for a used starter is getting hosed. Escpecially when they can be bought for $60 new with a lifetime warranty.
s13point5
Car: 89 240sx
Racinjitter wrote:The napa part number that is confirmed to work on a RB25det is 2444514. Link to hybridz thread with pictures on the second page. http://forums.hybridz.org/show...arter
if this is true. but does anyone else think the napa starter in this picture looks bigger than the RB starter and therefore wouldnt fit or bolt up?
jsack
Car: 1989 240sx rb25det
west covina nissan in california can get jdm parts i'll look up there phone # tomarow.i bought most of my parts through them for my RB25
HOMEMADE240SXTURBO
Car: 1989 NISSAN 240SX KA24E
Here is WestCovinaNissan
866-828-8814 or 626-732-1000 Parts Department
300Plus
Car: 1995 S14 w/ Rb25det Series II
ok ok I don't have the part numbers with me so this may be a pointless post but I got all my info from the hybrid z forum, so the part number should be the same. Got it from NAPA
And I can confirm it bolts up, but that is all I can confirm. I thought my starter was dying so I went this route and ran into one problem since the solenoid is in a different location then the stock RB starter and the over all diameter of the motor is so much bigger, it hits the heater hose tee. So much so that it makes it impossible to use. I tried moving the heater hose around and no luck, so if you aren't running a heater like most hybrid z guys then you are good. I took it back and was going to take some time and go over a bunch of starters with a buddy of mine that works at napa to find one similar but with the solenoid in a different spot, but never got around to it since my RB starter turned out to be fine. Was going to do another write up about it but got busy hope this helps someone.
But here are comparison pics for you guys:
s13point5
Car: 89 240sx
300Plus wrote:ok ok I don't have the part numbers with me so this may be a pointless post but I got all my info from the hybrid z forum, so the part number should be the same. Got it from NAPA
thank you for the better picture. it does look like it bolts up now. i dont drive my car in the winter but a little bit of heat is a good thing for those chilly fall days. so you are saying no matter what you do, you cant get the napa starter to work with heater hoses??
s13point5
Car: 89 240sx
actually now that i look at it, it appears that there is two different napa starters.
here is the starter from the hybridz forum
and here is the starter that 300plus posted
it looks like the starter solenoid on the hybridz picture is closer to stock position. now im confused. 300plus can you see if the napa part number you used is the same as the one from hybridz forum in this post ( http://forums.hybridz.org/show...arter) ?
300Plus
well I'll have to find the pic I took of the part number... But I took the part number to napa and the pic they had on their computer showed the solenoid close to stock position but when it arrived it was not the same as in their picture, they confirmed it was the right part number and said the picture just must be wrong. I guess without the part # we can't really get to the bottom of all this.
s13point5
Car: 89 240sx
yea that part number is key. i think you can see the difference in the pictures as well so i know im not going crazy haha
Racinjitter
300plus, it looks like you have the 2444517 number instead of the 2444514 number. The main difference is the clocking of the solenoid.
I remember talking to you about this part number, but that was before I had the 2444514 number. Scotty has tried this starter and it worked perfectly in his rb25det. He aslo said that it makes a completely different noise than the factory starter. I believe that it makes a different pitch due to the factory starter having a plastic ring gear instead of a metal one.
blurrbosi
Car: 240's
2444514 worked for me! SOOOO CHEEAAPPP!!!! Its like a 76 datsun starter.
bumblebtuna
Car: rb25/26 2fotay
STICKY!!
...or replacement parts F.A.Q!!!
300Plus
Racinjitter wrote:300plus, it looks like you have the 2444517 number instead of the 2444514 number. The main difference is the clocking of the solenoid.
Awesome that is good to know! I was worried only ppl without heaters could use this but if the 2444514 part number has the solenoid in a different spot then that is a great find for RB guys!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
NICO FTW, you guys are awesome!
Oh by the way, what type of noise does it make with the metal ring? Since I'm a at heart, lol. And I love sexy noises from the motor.
(Holy crap what kind of starter do you have?) napa part number ....... lol
BigPar
Good thing I brought up that Napa Starter Part thread, just couldn't find the link. I'm planning on doing this same thing as mine makes a noise cuz it doesn't back out fast enough after cranking her over.
Adrian gt
Car: 90' 240 hatch, 90' HT supra
my local dealer can get them
