rb25det starter issues
Spazz
ok figured out that my ecu wasent bad , lower and upper harness work, but my starter came without a switch wire.....
just wondering if anyone can confirm where the *&^% i can solder the ka switch to.thanks
eh?
try looking from the bottom, I don't remember on the Rb25 starter but on my RB20 starter the connection is below those two terminals.
yellow_jacket
Car: 95 240sx
My starter is lying on the floor, so when I picked it up to look at it the switched power terminal is on the left side of the solenoid(battery wire was at 12 o'clock). It is a male spade terminal. If you clean everything up you should see where the rivet is that held the terminal on or something.
