LJBS14 wrote:As far as the maf maxing out i thought stock rb25 mafs could handle at least 350hp with a proper tune? .
You may be right, Im probably thinking of the stock turbo not being good for much..
Im still a little weary about this tune though. I dont believe too much in off the shelf kind of tunes that are supposed to work on whatever, like this is what i have on this engine and boom heres your file to upload and youre done.. It may be a good starting point, but you wont know til you get the car up to temperature and give it WOT with your wideband hooked up.
If everything mechanical checks out and theres no boost cut features in the ecu, the only variable left is the tune.. Post back with the AFR you see at full boost, or when it starts breaking up.. If its lean, you have fuel supply issues, if its rich, it could be too much fuel or not enough spark..
Also, check a spark plugs porcelain for black specs or for diamond looking shiny specs just for safe measure.. Thats a good way to see if youre engines knocking itself to death.. Hope this helps.m
