everything is stock. I've tested the tps and it gets the voltage I posted above. My maf checked out right I believe, but what voltages should the ECT and knock sensors be getting?KUILLIN_DRIFTER wrote:you using the stock maf or z32/q45 also about the throttle body rb/q45? if all stock you need to start check voltages from the tps, maf, water temp sensor knock sensors. Once you check those then also check to ensure all your injectors are firing and clean and treat your coil packs springs and copper contact area.
ok... so i got a different multimeter just for the benefit of the doubt and now everything seems to check out right, except for the tps signal voltage is way off, but at least it's responding.eh? wrote:Don't use a test light. The cicuit is most likely low amperage so you don't want to use something like a test light. I think the black/light blue wire is the ground. Use this site to get all your information.http://paulr33.skylinesaustralia.com/diagrams.html
Pin 30 is the ground.Check for continuity at the tps AND at the ecu coolant temp sensor
wow... how bout this!!......eh? wrote:Sounds like an ecu problem, are all your ecu grounds hooked up? Try adding a ground to that wire, see what happens
believe it or not.... with your help and the correction of me retardation I think I may almost have everything straight....eh? wrote:Kinda hard for me to understand what's going on. When you disconnect ecu coolant temp sensor plug do you get a good ground at the black/light blue wire?
The knock sensors are on the lower harness, did you hook it up? They are single wire sensors, look at this diagram, the plug is A-24 and the wires are af14, and af21. http://www.gweeds.net/carpage2/rb25diagram.jpg
dood... thanks so much!!! you've been extra helpful and I finally got this thing running strong... there was one more ground that didn't get wired somehow, so i hooked that up, reset the ecu, set the timing and everything works perfectly now!!!eh? wrote:Sounds like you have grounding issues. I checked out the internal layout of a s2 ecu and pin 30 just goes to case ground. Make sure all your ecu grounds are good.For the knock sensor make sure the socket is secure in the plug. I think I've had mine pull out when I connected it to the sensor.
