my240gts »
https://forums.nicoclub.com/my240gts-u183983.html
Fri May 27, 2011 12:34 am
hi all i have looked all over for some info about the problem i am having with my power fc... all i can find about it is that if the controller is not match to the ecu it will be stuck on the apexi logo.. well i bought mine off ebayer from a guy that said it was bought new but had sold the car and never used it.. it came in a bundle bow with the ecu and controller together i have also checked on the controller it says FCC3 ( so newer style) and the ecu says ECR33 ( so newer style)... to me it seems as if the screen kinda blinks when it is stuck on the apexi logo could this be cuased from a ground issue for the ecu?? i have it swapped into a s13 and did all the wiring my self found on the internet. have had the car running with stock ecu.. if more if is needed just ask..!
thanks alot
