rb25det series II build any suggestions?
otightitzjim
Car: S14 kouki baby
hey guys. im building my rb25det series 2. i have a big list of things that im getting done to it and i just want to see some feed back on what you guys think. here ya go.
-----engine------rb25det series II -custom engine mounts-garrett gt3082r-6boost baller turbo manifold-tial 44mm wastegate-custom dump pipe-3in downpipe-greddy intake manifold-q45 80mm throttle body-300zx fuel filter-nismo fuel pressure regulater-power fc L-jetro with commander-greddy 4in front mount intercooler-walbro 255lph fuel pump-nismo 740cc sidefeed injectors-greddy timing belt-belt tensioner-koyo 3in radiator-samco radiator hoses-greddy type rs bov-blitz duel solenoid sbc boost controller-z32 mass air flow sensor-two individual electric fans-tanabe concept g 3in catback exhaust
-----internals------full mid-end race port-port and polished-decked head-tomei cams type a 256/256-tomei valve springs type a-supertech racing valves-valve job-upgraded valve guide-decked block-hot tank-bore and hone-blueprint and balenced-micro polished crankshaft-cp forged pistons 86.5mm .020 over bore-eagle forged rods-apexi 1.1mm metal headgasket-arp main studs-arp head studs-full gasket rebuild kit-full acl race bearings-oem oil pump-n1 water pump-nismo thermostat
-----drivetrain------lightened flywheel-spec stage 3 clutch-aluminum 1 pc driveshaft-nismo lsd
another thing is everything thats being taken out will be for sale. so let me know if anyones interested. i have alot of stuff!!! engine was in good running condition.
Modified by otightitzjim at 11:15 PM 11/19/2008
