Not a super big diff, the years, series 2 being the latter, the wheel on the s1's is glued on, and comes off at hi boost, s2's have a steel wheel which doesnt.240slidekat wrote:what is the difference between rb25det series 1 and series 2? is there away to tell which is which? just wondering sorry for the noob question.
Actually there are two types of transmissions, and the easiest way to tell them apart is size, most series two motors, come with a larger transmission alltogether while the older ones or depending on what car it was in, have a smaller transmission.Kamin wrote:they only have 1 manual transmission.
I'm not sure where you heard that, but I know all r33 RB25DET skylines came with the same manual transmission. You can verfiy that with the Nissan FAST.Kansei240sx wrote:Actually there are two types of transmissions, and the easiest way to tell them apart is size, most series two motors, come with a larger transmission alltogether while the older ones or depending on what car it was in, have a smaller transmission.
seriouslyeh? wrote:I'm not sure where you heard that, but I know all r33 RB25DET skylines came with the same manual transmission. You can verfiy that with the Nissan FAST.
yah... does anyone know? he he heReignman wrote:Does anyone know if a series I wire harness would work with a series II engine?
