I know there is a DIY thread about this but the pictures no longer seem to be there, I just had a few questions on installing a "Freddy" manifold onto my S2 RB25DET.
So my questions are: Can I connect the turbo water feed or return (?) coming around the back of the block (D) onto the Tee coming out beside the thermostat spout (A) or is (B) better to use?
Can I just block off that rear Tee (B) with a bolt clamped into a short hose otherwise?
Does the other pipe coming out of the AAC valve (C) go into a bung welded into the boost piping before the throttle body? Assuming this is what they refer to as the "cold start pipe" ?
Is it true that if I'm putting this engine into an R32 Sedan, that I'll need to change my clutch master cylinder to the shorter R33 master cylinder to clear the new manifold?
I plan to relocate the battery to give me flexibility on the best spot to holesaw for the intercooler piping, as I'll be keeping stock throttle body using an adapter so it will sit even further forward.
Not sure on a better way to host these images, suggestions are welcome and hopefully Imgur works
Labelled photos in question: http://imgur.com/a/T1vY8
Cheers for any help!
