rb25det s2 auto w manual transmission posible?
nomenai
hi i need some help to find out if i can use an rb25det s2 auto, and change the auto transmission for an rb20det transmission 5 speed?if is posible do i need another acu? or wire harnes? or what do i need to make it work thanks
Modified by nomenai at 2:33 PM 12/12/2006
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
you can use the rb20 transmission but the ecu will most likely have to be changed for a 5spd rb25 ecu (due to idle problems i believe).
You'll need the Rb25 engine harness of course. The lower harness will use the rb20 transmission harness.
