rb25det S1 Valve adjustment
ANVIL
Car: RB25DET S13.5
what is the spec and how do I do a valve adjustment on my rb?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
They are hydraulic lifters, so there is no valve adjustment. The oil pressure pumps the lifter buckets up to take up the slack between the lifter bucket and cam lobe.
Why do you ask?
USsil80
bad lifters???
Cjmartz2k
Car: Hunting for a '89 GTR now
USsil80 wrote:bad lifters???
Common problem. I had 2 motors with bad lifters. Every time I'd heat up the oil......ticky ticky ticky.
ANVIL
Car: RB25DET S13.5
still trying to figure out my misfire from this thread:
help-to-get-my-car-running-right-lots-o ... 07304.html
had someone suggest it to me, and i was pretty sure there was no adjustment, but i just had to ask. also is it possible to have 155ish compression and have a bent valve? i was pretty sure there would be no compression with a bent valve but im just trying every angle to try to figure this out.
240z4u
Car: '95 Nissan 240SX
If your compression numbers are that good, bent valve is VERY unlikely unless its stuck shut. I am sure that would make one hell of a noise.
ANVIL
Car: RB25DET S13.5
thats what i was assuming but im willing to listen to any ideas at this point....
Joe
are you running on all 6 cylinders? if you are, probably a turbo seal.
