bronson808 »
https://forums.nicoclub.com/bronson808-u181621.html
Thu Sep 20, 2012 8:09 pm
things i did was clean iacv, clean o2, and wire the mafs 12v ground (not signal ground) to firewall.
also i guess i had the tps connector plugged into the wrong plug on the tps( carlh you were right) so plugged that in adjusted it to .4v closed and tryed to start it wouldnt start with maf plugged in OR unplugged i could hear it wanting to turn over but didnt.
so my lovely fiancee which who was inside the car trying to start it for me while i was messing with the idle screw on the iacv was like "maybe you need gas". so i figured get a gallon of 92 throw it in there and go from there.
so we did that and the car started without the tps and mafs plugged in. i had to play with the throttle plate to get it to start and idled kinda rough, i plug the tps in instantly smoothed the idle, then plugged the mafs in and it ran good at times, i could hear it surging and wanting to die and then it surging goes away and runs excellent then surging comes back again and so on. i think it might be because of the bov vented to atmosphere and maybe the stale fuel and good fuel mixed together? im going to also throw more fresh fuel in there to knock out the possibility of fuel still being crappy cause its only mixed with one gallon of fresh fuel as for the bov im not to sure what i am going to do as my bov is where my battery was. id hate to run a hose all the way across the engine bay to the intake.
so anyway in the first place the car wouldnt start with the maf plugged in. so with the car warmed up fans came on i turned off the car and went to start it again and had to play with the throttle to get it started, idled rough and would die if i didnt play with the throttle, but if you keep it from dieing it will eventually idle pretty stable as surging comes on and off.
so for now im waiting till it cools down and im hoping for no problem with starting it cold.
questions:
has anyone had and similar experience with bad fuel and not starting or hard start?
has anyone had same situation and turned out to be iacv bad?
what does the air reg do?
bronson808 on Thu Sep 20, 2012 8:49 pm, edited 1 time in total.
