JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Fri Jul 09, 2004 2:08 pm
On your ECU there is a screw(kinda) on one side of ecu with a little window next to it. turn the screw all the way one direction, then all the way the other direction and it should start the LED inside the window blinking...if ther eis no LED then you gotta hook up the check engine light and it will flash....55 (5 slow flashes, then 5 quick flashes)is all clear, anything else, post it and we can look it up for you.
I would say that you start by checking for a boost leak, sounds like what you have going on...or maybe the timing either of which the ECU wont show you.
