RB25DET Run Test (In Clip)
Lbax
Car: 1990 240SX
We just purchased a RB25DET Clip from a Skyline. I want to do a run test before I pull the Engine from the clip. Battery connections appear straight forward. Fuel connections are another issue. I have the fuel pump from the clip. However, I am having trouble locating documentation on a temporary fuel configuration to test the clip. Any suggestions? Thanks in advance
Carl H
give it power and ground it will be fine, thats what the fuel pressure regulator is for.
Lbax
Car: 1990 240SX
Carl H wrote:give it power and ground it will be fine, thats what the fuel pressure regulator is for.
Thanks Carl, I was less than clear. The electrical part is not the key issue. I can get the fuel pump power with no problem. I am most concerned with the plumbing & mechanical side of a temporary fuel pump/tank configuration. The thought of putting the powered pump into a open bucket of gas is not appealing. This was the approach suggested to me as no fuel tank came with the clip.
I was considering running a fuel supply line from another running car to avoid this perceived hazard. Thought I would ask how I is done elsewhere...
