RB25DET rough idle, cuts out and won't rev over 2500rpm
gts155
Car: Skyline gts
It won't idle , cuts out and won't rev over 2500rpm.I have change the mass air flow and coolant sensors and the lamber sensor, spark plugs, throttle postion sensor. any 1 got any ideas??????
KlanjacOFF
Car: Nissan 240SX
What does it do while you're driving it under load?
rotorimp
Car: 02 Xterra, 60 IH Metro
What is your fuel pressure
gts155
Car: Skyline gts
it trys to put ya through the windscreen, it kangroo's real bad!!
gts155
Car: Skyline gts
can't rember, will check again!!
KlanjacOFF
Car: Nissan 240SX
My corolla did something similar to this one time and it ended up being a bad ground. So check those
mello88
Car: s13
gts155 wrote:it trys to put ya through the windscreen, it kangroo's real bad!!
hehe
Anyway no rev over 2500 usually means a problem with the MAF or the MAF wiring. Pull the codes off the ECU and see if that helps you out any. It's possible the MAF wiring itself has a short in it...
Also check the obvious stuff, like boost/vac leaks
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Usually MAF wiring like mello said.
