why raise it on a stock engine? nissan put the rev limit there for a reason, and their engineers are smarter than most of us. unless you have the cams, valvetrain and power needed for more RPM you are only wasting your money and endangering your engine.StricNyne wrote:good pic btw..... wut i mean was that i can raise rev limit beyond oem setting, i am gunna goto dyno friday, and i will see if i am getting power beyond stock revlimit, theni will raise it but keep it under 7500 probally
Still, the engine still runs out of steam at around 6800.Sil240 wrote:he wants to raise it because he has a bigger turbo I wouldnt go past 7500 either, and i would get a Soft touch revl limiter and a FCD
That is NOT true...IT depends on your set up, your powerband.....A big turbo with later spool is and a flat powerband is going to make power throught the higher rpms..y3llows14 wrote:
