Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Sun Nov 01, 2009 10:28 am
I think it's more a function of the turbo being the choke point, not anything in the head at that power level. That being said, yes, I could see the stock cams providing better top end at the expense of power somewhere else. Keep in mind if you are keeping VCT, you can only use one adjustable came gear. I think you should be adjusting (or keeping) the cams right in the middle of your power band on a stock set up because that's where the undersized RB25 turbo is making most of it's money.
Size and adjust your cams to where you want to make the most power. Putting huge cams (or adjusting cams for the most top end) on a small turbo'd car where the turbo is choking it out anyways kills low end and doesn't help top end. Now if you had a big turbo that pushed a lot of air up top (6k-8krpm), and was a little soggy below 5k rpm, then stock cams would be the limiting factor. Adjusting them towards the top end of the power band would help some I think (more than on a stock turbine car), but bigger cams would be the best answer.
