RB25DET rebuild
s14_sport
ok so i decided to rebuild.
got low compression on cyl 2 & 5. below 50 on both and all the other were between 145-160. Leakdown test performed and got the compression to pretty much double on 2 & 5 so I'm pretty sure rings. So I'm diving into it this weekend. I have a spare RB that I'm building up and this one in my car with the low compression needs to be up quickly with just minimal parts.
I just planned on replacing all the rings and the head gasket. Is there anything else I should look into replacing while I'm at it?
Carl H
bearings since you're in there...
s13point5
Car: 89 240sx
bearings and all your gaskets.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Valve stem seals
Rod bolts are an inexpensive part to toss on there as well
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Just hope that it isn't a cracked ring land or something.
s14_sport
well yes, lets hope its not that...lol
so far im replacing:
piston rings, all gaskets,bearings
