rb25det rebuild (lifter & stock oil cooler) questions
StricNyne
i was just wondering where i could get a replacement stock oil cooler for my rb25det, the shop whom has my motor told me i have to replace the stock oil cooler , can i bypass it or replace it, also i was told during my rebuild of the head i have a bad lifter where can i order a new one, or does someone know someone with a rb25det series 2 head and is parting it out, or is there is a xreference for the lifter with lets say vg30 or ka or something of that nature...
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
You have an RB25, right? I don't know why you would need to replace the stock oil cooler because there isn't one. Are they talking about the water-cooled oil cooler where the filter is?
RB_Dreamin
darius....an oil cooler is an oil cooler, doesn't matter if its air or water cooled. the rb25 has a stock oil cooler....
whats wrong with it that they want you to replace it?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Yeah I believe that's what he was talking about.
I don't know about the Z32 lifters working in the RB25 but I belive they work for the Z32.I know alot of the Z32 and RB20 head parts are interchangeable.
I've only seen a picture of this oil cooler thingie once. Can it just be taken off??Or does it have fittings to connect to a regular universal air to oil cooler??
Bluefire
Did they say the cooler is leaking coolant or water into either system? if so I have a stock rb25 cooler... email me
Sil240
OK just talked to him.He said that the machine shop said that when you rebuild the motor there is a Diaphragm in there that you should change when you rebuild.
From what he just told me I don't think that it's broken (might be though).
Does anyone have the FAST program working???
He needs the part number for the Diaphragm and the lifter. Maybe it'll crossover to a US part.
He may just buy a whole other one too. Dunno.
Darius
I know it has an oil cooler, that's why I asked...
Darius wrote:Are they talking about the water-cooled oil cooler where the filter is?
I was just surprised that they said it needed replacement because there are no moving parts in it.
Basically, it is a very small heat exchanger. The coolant comes in and passes through a separate passage around the oil passage as the oil enters/exits the filter. The coolant picks up some of the heat. It would be tough to get rid of it completely because the housing has a weird gasketed connection to the block. You could disconnect the coolant lines and bypass the stock cooler, but it was there for a reason.
StricNyne
back !!! i will get info from the guy tonight, for oil cooler but the lifter is what scares me the most
integra7
Car: 1995 Nissan 240sx
RB25DET Hydraulic lifterUSDM OEM Part # 13231-79S00
StricNyne
hajjluah !!!!!!
Darius
Hey StricNyne, do you want to find the interchangeable parts thread and add the hydraulic lifter to it if it is not already there? For some reason that part number looks familiar so it might already be in there.
eh?
Need to replace oil cooler? Bad lifter?Who's doing this rebuild?
Darius
StricNyne is the one in need of parts.
300Plus
Car: 1995 S14 w/ Rb25det Series II
Hey man, Nate yanked his off and just added a radiator style oil cooler. You just need the right fittings
StricNyne
ok here is the skinny !!! he just said oil cooler needs to be replaced he is gunna swing by my house and show it too me, while inspecting all rebuild parts he noticed i was missing couple bearings which i got coming to me, and that i am in need of ONE lifter which i am gunna buy from courtesy nissan, but this oil cooler is rly scary rebuild is from bauxbros they do a lot of dragsters as well as a few sr20s
eh?
Did he try to bleed the lifter?
Carl H
what is wrong with the std oil cooler, i still dont get why it needs to be replaced. if anything remove it and slap a sandwich plate with thermostat in its place.there should be a center bolt thru the cooler, just remove that bolt and remove the cooler and done deal.
RB_Dreamin
eh? wrote:Did he try to bleed the lifter?
Do you really think StricNyne knows what he is doing? All day long, he just makes posts about his dreams. It was only last week that he posted up how his dreams were shattered due to budget issues. The next day, he starts posting about gas coolers, solid lifter conversions, etc. I guess you can't stop dreamers from dreaming (even when they are broke as ****).
StricNyne
i dont know what i am doign, i never rebuilt a motor thats why i sent it to a capable shop, yes i coulda picked up a book and read and attempted it my self, but i rather have peace of mind and get it done professionally and know its done right. well i guess i am a dreamer..... i think all goals start out as dreams but for me they usually happen via my hardwork, and dedication so i guess that makes me a successful dreamer in the least...you on the other hand are a loser, you dream of having a rb, you dream your cool, and dreamed up a name to harass and insult people but in reality your just moron... i think the dream is over.....
Sil240
He also actually is Boring and stroking his motor. Did I mention TWINS Basil TWINS (Fook U & Fook Mi)He's not just dreaming of gas coolers, GT500 N1 Blocks, or anything.
Your dreams will soon be His Reality. :-)
StricNyne
imma let the haters hate, my car will speak for its self in about a month....anyway still need to figure out this oil cooler scenerio but mahcine shop guy didnt stop by sigh.... bhut as of now thats my only bottleneck, i will talk to nate (rbtally thnx kyle !!!) tonight and ask what he did and why he chose to replace it
Sil240
**COUGH COUGH** Intake Manifold**Cough Cough**Haltech Wiring
Drink up Beetches. lol
StricNyne
oil cooler must be replaced cuz its contaminted, imma just rought it into itself then run an external from the filter housing !!! i got a lifter on order, and sean (THNX BRO!!!) at takara motors has some bearings for me so the issue is resolved... i got all money saved up for the rebuild finally, now i am saving up for DP fab for the twins and once i sell some of my stuf and my rb stuff i dont need cal will be DONE
StricNyne
well i saw the head last night and it looked amazing he is gunna deck it and do machine work on it tonight then we wait for the parts
