RB25DET & RB26DETT starters the same/interchangeable, yes/no?
Indolent
Car: coupe
http://forums.hybridz.org/showthread.php?t=125150I need a starter for my car (26 pull type trans), ^ above shows a napa starter that works but I believe that's for the 25? Not sure if the 25 & 26 starters/flywheels are the same
gawdzilla
Car: none
yes, napa pn 2444514 or something
Neejay
gawdzilla wrote:yes, napa pn 2444514 or something
NAPA: datsun 65-67 411 (p/n RAY2444514)
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
my rb26 starter had more teeth then my rb25 starter so beware, im sorry i already sold my rb26 starter to one of my gtr buddies otherwise i would hook you up.
Neejay
HxC_Nismo wrote:my rb26 starter had more teeth then my rb25 starter so beware, im sorry i already sold my rb26 starter to one of my gtr buddies otherwise i would hook you up.
errr...sorry, yes, that was for the RB25. Not sure about the RB26...sorry.
gawdzilla
Car: none
what clutch/flywheel are you using?
i've never confirmed whether or not the 25 and 26 flyhweels are interchangeable. that should be the only deciding factor between starter interchangeability.
i am running the 2444514 starter on a 26 motor with a 26 push type clutch/flywheel (exedy NM033sr) and a 25 trans if that helps.
StricNyne
what is price on that starter ?
