johnny butt »
https://forums.nicoclub.com/johnny-butt-u81072.html
Mon Oct 06, 2008 3:49 pm
Swapping an Rb25DET 5spd into a '93 S13.
I've read that the z32 speed sensor will work if I want to get my KA DOHC Cluster to read the MPH correctly, but the threads I've looked at have never stated whether it's from a TT or a NA? And I'm also just going to assume that it has to be for the Manual transmission? Not that it matters, but what year should I also look for?
Anyone using one of them, did you get it the one for the NA or the TT? I would assume it is NA since that is the same clutch type (?) but I don't have a lot of time to wait for parts to come in after I order the wrong one, so I'd like to just order the right one the first time.
Also, I am in need of an IACV, and have read that early model (91-92 or so) Sentra 1.6 IACVs will work. Can anyone else confirm this? Autoparts stores around here all have to order it and I don't have tons of time to wait on ordering parts more than once.
And i have also seen that BCPR6es-11 NGK spark plugs (Copper - Nickel Alloy?) would be good to use for the RB25DET, but what should they be gapped to? Their specs chart says about .043-.044", which comes to about 1.1 MM but I have read that .8mm is ideal. Can anyone else verify they've had no problems with this?
I also couldn't find any replacement for the PCV Valve.
Anyways, those are my 3 biggest issues for parts that i need to replace before the motor can go in.
Thanks.
