You are correct sir, purple plug is for A/C idle up. Brown is AAC. Something you definitely want working.gawdzilla wrote:the A/C one is the FICD with the purple plug i think on the 25.
the AAC controls the idle at all times.. motor will probably idle hunt a lot without it. either that or you would need to idle really high
