driftingmy240sx wrote:at that hp level you would need to have the crank sleeved with an oil pump collar. would probably want to put new acl race bearings in the bottom end with maybe some new rods and pistons. you will also want to get a twin disc clutch to prevent the transmission from blowing 3rd gear out. a new ati or fluidyne crank pulley would be wanted also. get a new cometic head gasket and arp head studs.
^^ so many holes in this ^^. WTF is with all these new guys spouting out regurgitated hearsay?? It is getting out of control.
1) Cranks don't get sleeved, blocks do. For any RB25 power level, the block will never need to be sleeved. That is what honda owners do...
2) Twin-disc clutches have nothing to do with the transmission. Like s14 said, it will be more abusive on the transmission.
3) An ATI crank dampener is not necessary. Where the hell did this come from and how does it relate to hp level??
4) Do not get a Cometic head gasket. Period. Any other MHG manufacturer puts out a superior gasket at a marginally higher price.
But to answer the original post, everything in the previous post other than that mentioned in the list above is accurate. Include smaller oil orifices for the block and add ~$10,000 to the list.
