Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Tue Aug 29, 2006 11:19 am
Death and Rebirth ProjectThis is a write up for just really anyone that needs a refresh or something like that. Ill try to include more of an indepth detail about it for certain bolts and TQ specs later for the RB community.
Well as some of you know my car had the wrong transmission, and i a year ago wasnt knowledgeable enough to notice the two slight differences between what i have, ( Assuming its an RB25DE transmission rather than a RB25DET which has a different slave mount and shift plate angle. Flat on mine, compared to sloped down at the back on the RB25DET.
So i am pulling the engine, going through coolant line bugs, and all the other essentials and doing a write up to where EVERYTHING on the greddy intake manifold goes. For those of you that dont have a manual or get the japanese moonspeak version that you cant read.
So in four hours i got the stuff disconnected and motor out.
To make pulling a motor MAKE sure you pull the shifter out of the transmissoin to keep it from snagging, this makes it much easier to pull, and also make sure you drain the transmission fluid out of bottom so it doesnt spill out of the shifter hole once you've removed the shifter. The bottom of most nissan trannies you can either use a bigass Crescent wrench or an allen wrench on that bolt becuase its go another small drain nut with an allen head on the inside of it.
Now if you live in the midwest or where theres alot of bugs... TAPE STUFF UP.. .And so things dont get dust in it or scratched up ( paint ).
Heres a quick list of things to remember to disconnect in somewhat order to keep from making a mess. BATTERY/and or POWERLINES FIRSTEngine Wiring Harness ( this can be draped to the side as seen in the picture and or hanging out of the car till the motor is back out. You dont really need to pull the bottom one, just make sure when you're pulling the motor out, that its securely ziptied to the motor. Exhuast components after the turboIntakeFmic/Smic PipesAny Vacuum lines or gauges that might run off wires electronically that go to the interiorRadiator hoses/Radiator/Fan assemblyHeater HosesFuel linesPowersteering systemHoodDriveshaftSlave cylinder lineMotor mounts ( loosen top nuts, or whichever you think will make it easier. I just undid the top isolator nuts. ) transmission mounts
Take the Radiator out, Fans, anything that could be damaged in the path of taking the motor out.
Now that it is out, to take the transmission bolts off or anything requiring torque, its a ***** to do while its on the hoist, so get a wrench and a hammer and tap-knock it loose and bam, now you can work some more on it tommaro.
