ok so recently i bought a s14 with a rb25det with a built bottom end and head along wiht greddy intake manifold and fmic and full exhoust. drawbacks are..... stock injectors ( only run car on factory boost with boost controller turned off , on 5psi) my oil pressure is at 50psi normal driving and 75psi in boost and my afr is 14.9 driving normal and 11.2 in boost..... i have checked for boost leaks. checked all vacume lines, checked timing and i have replaced knock sensors along wiht harness. know my car when i drive it it drives perfectly fine if i shift before 2500rpm but if i mat the pedal to the floor it feels like it hits a barier and doesnt want to rev fast nor does it want to move its just a slug in boost. idk why its doing that nor can i find a problem. then for a while it was cutting off at stoplights or whatnot unless i held the throttle down enough to sit around 1200rpm or so. but i replaced spark plugs also thinking it would help and went to a colder plug (bkr7e over the ones in the car that were bkr6e) and it idles a little better and drives smoother but still doesnt drive right. it still hits a barrier when entering boost and its not everytime sometimes it has some pull but still not alot. please help idk what else could be wrong i was thinking maf sensor but im not 100% sure.
FORGOT TO MENTION CAR IS A SERIES 1 RB25DET. AND IS RUNNING A SERIES 1 MINES ECU ( DOESNT HAVE A LED LIGHT IN ECU TO RUN CODES NOR DOES IT HAVE THE DIAGNOSTICS SCREW.) AND I DONT HAVE A CONSULT READER TO CHECK CODES
AND THE FACT NISSAN WANTS $100 TO RUNA DIAGNOSTIC AND TELL ME WHAT THE CODE IS. NAD ID RATHER SPEND $100 ON WHATEVER IT IS TO FIX IT.
what im trying to figure out is what you all think could eb wrong wiht it based off expeierience becouse i am a sr guy by nature and rb's are all new to me so i dont know to much about them or the probelms people encounter with them but i have been searching and searching and searching for answer but have come to nothing solving the prob
i know for a fact im trying to buy 550cc injectors and a 300zx maf and get my car tuned ona r32 rb20det chipped ecu but im trying to findout what the probelm is first. any opionn or help is greatly needed thanks
