RB25DET Pro Series wiring harness is here!
Wiring Specialties
Vendor
After much research and development, our highly anticipated RB25DET PRO Series wiring harness has arrived. This sleek new harness is 100% plug and play and comes with a startup guarantee!
It was designed in house on an actual RB25DET engine and supports most ECU's, injector types and MAFS. Wiring your RB25 swap has never been easier!
Only $599 for S124 and S14 240sx. - ORDER HERE: http://www.wiringspecialties.com/rb25det.html
PRO-SERIES HARNESS SPECS
• Plug and Play.
• No cores or additional wiring required.
• Point to Point continuity tested on every wire.
• Constructed using OEM connectors and seals.
• Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing.
• Wrapped in lightweight nylon loom with -94C to +257C operating temperature.
• Includes a charge harness and improved grounds.
PRO-SERIES HARNESS INCLUDES
• Quick disconnect MAFS/AEM/Haltech/PFC Speed density extensions (change from MAFS TO AEM/Haltech in seconds).
• Coil harness sub-harness.
• Knock sensor sub-harness.
• Transmission harness with reverse and speed sensor wiring.
• Alternator charge cable.
• Nissan Diagnostics connector.
• S13/S14 Power and dash interface connectors.
• Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
outlaw7
Car: 78 zed
Cool, thats exciting!
Did you guys ever finish the ls2 coil to rb subharness?
Wiring Specialties
Vendor
outlaw7
Car: 78 zed
Lol, I meant the rb25 to ls2 coils sub harness that lets you connect ls2 coils to the rb harness, you guys dropped a picture about it on FB a few weeks ago and then nothing ever came of it, at least not on your website.
Wiring Specialties
Vendor
yeah we can build them for you, just shoot us over an email and we can assist you: [email protected]
fnmadog
Car: 1993 Nissan 240SX Vert (no engine)
1991 Nissan Skyline GT-R
With this harness i can wire up the RB25DET into a S13 w/ the S13 instrument cluster and all my gauges, clickers, switches, and nobs are going to work? No need for hacking up a r33 tach into the dash? also is this the same harness offered by RawBrokerage here ?(http://www.rawbrokerage.com/raw-brokera ... ckage-s13/)
developing a plan for getting the instrument panels functional is biggest thing holding me back from this swap.
Wiring Specialties
Vendor
Yes everything will work for you stock (s13 gauges) in your car. no need to "hack" anything up at all. We offer two different harnesses for you.
Pro Series:
http://www.wiringspecialties.com/wsprrbs1ands.html
OEM series:
http://www.wiringspecialties.com/rbwihacofor2.html
fnmadog
this is good news. i like plug and play wiring.
i'm currently shopping for a motor/trans not sure if it will be the S1/2 or Neo yet. I'm aiming for the S2 but price and availability will dictate.. when i'm home in a few weeks i'll be removing my ka and trans, maybe we can make a trade??
Wiring Specialties
Vendor
I am sorry we have no need for used motors/trans
