RB25DET powered 240z dips into the 9's
240z4u
Car: '95 Nissan 240SX
http://forums.hybridz.org/showthread.php?t=155627
Same car that was in the z vs. turbo viper video within the last couple years.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
ahh an automatic would be awesome for drag racing.
Great times out of a stock bottom end!
meet07
Car: 89 180sx rb25det
a trap of 140+ with the th350......thats great!!!!
I so want to do this swap. Is this the same car racing the 300zx with a rb26, 20psi and 75 shot of nitrous???
that might be the 1st 9 second rb25 powered vehicle in the states!!!
240z4u
If you read the thread, it gives a breakdown of exactly what he is done. I think its a 125 shot.
It might be the same car as the one racing the 300zx, not sure. I do know he is friends with a guy who drives a 26 powered z32.
nissandrftr88
Car: 34 240'S, 3 rx7's, 06 & 07 gsxr 1000
240z4u wrote:If you read the thread, it gives a breakdown of exactly what he is done. I think its a 125 shot.
That his next door neighbor..and yes same car.It was an awesome race,jt ran his first 9 and my friend sam ran his first 9 ftw!
flatrate
Car: S14 kouki
why the nitous the turbo is likely capable of the power on boost alone??
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
flatrate wrote:why the nitous the turbo is likely capable of the power on boost alone??
Most use the Nitrous to spool the turbo and get the car out of the lights. The Rb does not make enough tq on a Big turbo setup.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Yup the nitrous lets him get up off the convertor and have the turbo spooled very fast. Otherwise a high stall turbo car is fairly laggy on boost alone. Also the nitrous cools the combustion temps alot.
flatrate
Car: S14 kouki
antilag?? i was able to build 20psi in a 4 cylinder with a 35R... im sure the RB could easily do that... is there something im missing?
DrifterProdigy85
Antilag is good for a stick car but then you deal with consistency problems. You also put alot of premature wear on the turbo from the combustion occuring to spool the turbo up. Its fine for a track only car but for quick consistent times an automatic is still better. Believe it or not but the nitrous is probably whats keeping his engine alive for so long with the 67mm turbo.
