wildacexxx »
https://forums.nicoclub.com/wildacexxx-u24543.html
Sat Feb 03, 2007 4:23 pm
rb25det swapped into a 1995 s14.w/ turbo back exhaust and fmic kit
when running the car to redline at wot, there seems to be a "dead spot" around 4-5k rpms... at this point it it is making 12 psi on just just the oem actuator. it will break up and then clear up and continue on till redline.
with a silencer installed, it limits theboost to around 10-11 psi. the same dead spot occurs, only more muted... it doesnt break up, but there is a lack of power in the same range...
the ecu doesnt throw any codes, mafs was replaced and is reading correct voltage at idle. all coils and injectors are firing. timing is set at 15*. knock snesors read correctly at idle...
car usually feels robust in the low end and throughout the rev range while not at wot, although it does sem to be lack a bit of power until after 5k rpm.
also, at around 6k rpm, there is a screeching sound coming from what i think may be the turbo untill redline...
i have been over every bs problem i can think of from boost leaks, to spark plug gap.
i was told it could be something with the nvcs but i have no idea how to check that. also something about a rich and retard mode.
can anyone offer any insight to help me get this motor making its full potential power with this near-oem setup?
