rb25det piston rumors??
xricanpapitox
Car: 1998 nissan 240sx / 1993 mazda rx7
ive heard that the rb25 internals could hold up to 500hp but i have other people telling me that the pistons are weak and they will crack? any thoughts?
Cjmartz2k
Car: Hunting for a '89 GTR now
People repeat what they hear from other people on the internet too much with zero experience. It'll do a lot more than 500, but tuning is key.
xricanpapitox
i had my rx7 built and tuned at PF Supercars in maryland and they also do alot of rb motors so the tuning i have no worries i have faith in them....so whats the deal on the rb25 internals?
eh?
They're cast pistons so don't expect 2JZ #'s stock.
StricNyne
my rb25 oem pistons sucked, the ringlands cracked and scratched up my cyc walls
krayton
yeah, rings are weak
wish there were more people pushing high numbers. i think im gonna do 450 for awhile. see how stock holds up
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I heard RB25 pistons had a lil bit of these in them .
xricanpapitox
yeah i was told the pistons crack easily that the rods are the strong point only...so i should do a piston rod setup just to be on the safe side
Cjmartz2k
Yes you should. We all should. Question is do you have them money and is it necessary? I know several cars making well north of 500rwhp on bone stock RB25's. I'm going to replace my pistons with forged slugs when they break, but I haven't managed to pop them yet, knock on wood.
Bluefire
It is no myth... I have seen a number of cracked pistons. Some due to minor knock, and others without a single nick on the pistons. Just a clean crack. It also usually the 1st ringland, but I have seen case where the piston will crack clean in half.
But to be honest, I still wouldn't build a motor until I blow it.
Cjmartz2k
It's no myth the pistons are the weak link. If the motor goes, that's usually what goes first. I'm saying they don't magically blow up at 500hp like you would be lead to believe on certain forums (not this one).
xricanpapitox
thx for the insight....ill just keep driving and build it when it breaks to save myself alot of money
Cjmartz2k
Keep in mind you can break it in ways that take other stuff out like turbo's, cranks, and blocks. The later two are pretty unlikely though. I have somewhat of a skewed perspective since I'm in Japan and can get decent RB25's for like $300. I would say run it till it blows though. It'll probably surprise you what it'll do and how long it'll go for.
Agreed though, it's not a 2Jz.
8gti9
Car: '91 240sx rb25det, '94 Passat VR6 Wagon, '06 Sentra Spec-V
are you guys talking about s1 or s2 rb25. i'm putting a s2 rb25det in my coupe and my hp goal is 350hp to 400hp. is this possible with stock internals w/ just a bigger turbo and higher cc injectors? thnx
Cjmartz2k
Both and yes
xricanpapitox
Cjmartz2k what are you running on your rb25?
Cjmartz2k
What do you mean, what turbo? Link to my "look at me" thread in my sig for mod list. Power wise? Low to mid 600's at the motor.
