how do i go about measuring the thickness of the ring grooves? im staying stock bore. just gonna hone the walls. so my stock bore is 86mm correct?nuts510 wrote:there are several companies that can make rings up for you, the problem is you need to get your pistons out so you can measure on usually turnaround time on getting a custom set our rings made up is about two weeks and a six-cylinder with a good high-quality rings usually run around $120 $150 a set, total seal is pretty accommodating about making rings up for turbo applications and has a good turnaround time. You need to know the thickness of your rings grooves and the diameter of your bore and also make sure they know it's for a turbo application.
$150.70 shipped with 3 day shipping. i will have to look at the paper i have at work for the specs and sizesCoolwhip wrote:how much were they from total seal? And what were the sizes or specs that they came up with?
Thanks
