Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Thu Jun 19, 2003 5:23 am
It doesnt take that much custom work for an RB25 swap, I think you should research the rb swaps a bit more before saying that it takes a lot of custom work. You can put an RB25 in using stock engine mounts and transmission mounts if you dont mind cutting a small chunk out of the skeleton support under your hood. Then you just need to have your driveshaft modified or have a custom one made up (not that friggen hard) and do the wiring (there's a nice guide in the RB section). It's not as hard as it's been made out to be. Also, as I said before...The SR20DET can take 4-500hp, but not for long...and that's assuming that its a perfect motor with damn near perfect tuning (in other words, thats why a lot of shops have been able to do it). If you had done your research well, you would realize that it's an aluminum block engine and that to reliably make that much horsepower on a 2.0 aluminum block engine you should definitely sleeve it. *hint: they use ductile IRON as the sleeves...the RB blocks are allready MADE of iron*. I dont know why everybody is so ready to jump on the SR bandwagon, it's a good engine, but its not the best thing in the world, there are a lot of good engines out there, dont just limit yourself to one particular one, research ALL of them and decide which one fits your goals the best.
