rb25det or kat
xero1
Car: 08 Altima Coupe
is there any difference in weight between an rb25det and a ka-t?
wild_maxx
Car: 90 TT pearl yellow z32
ahhh not sure on the weight... but the RB does have 2 more cylinders so my guess would be that its heavier.
The weight of the ka-t would be different for all setups... depends on what you put on the motor.....
Toshima
Car: 93 240sx, 93 sc300(m/t)
Plus the rb25 uses a big transmission so more weight. But I dont really think it would make that much difference in handling.
Tictakman
i think its like 100lbs give or take.
ive had a built kat pushin around 300 rwhp and i now have a rb25det. the big difference i see in these engines is the kat has the low end "quick" response power, although it sounds like its always being pushed. i was at 15lbs of boost on a t3super 60
on the other hand the rb25, which i havent boosted past 5lbs on a gt35r is a little more hesitant from what it seems like, but it does need a tune and boost turned up. another thing is that the rb doesnt even seem like it is straining when i mash the gas, again its at only 5 lbs though.
weight in the car isnt really that bad, i had the kat in a s14 and the rb is in a s13. the s13's rear end comes around quicker than the 14 did.
sound, love the sound of a straight 6...
Zak
klattr1
Car: GT42R powered S14/KA
Tictakman wrote:on the other hand the rb25, which i havent boosted past 5lbs on a gt35r...Zak
wheew, i hope you do plan on boostin alot more on that turbo hehe...
i agree, RB's do sound pretty mean out the exhaust...a stock RB w/ exhaust revving it up makes it sound like it has a few hundred HP more than it really does...
but i would do a built KA-T over a stock internalled RB anyday...
Carl H
for the money you'll spend on a STOCK rb25 install you can have a built and turboed ka with good management.a stock install will run you about 4.5-5k on a rb25 and with that money you can have a fresh motor with plenty of potential...
wild_maxx
and carl H is a very smart guy when it comes to the RB. If he's sayin go ka-t that should be enough reason to do it!
Iamjohnhayes
Car: 89 Single Cam Hatch
also depending on if you go crossmemeber or mckinnley mounts you may have yto trim hood bracing b/c the rb comes farther forward. its also another thing to think about that even though the motor may be close in weight it does over hang the front wheels more.
Tictakman
i think it a question more of do u want to do a engine swap and do custom modification. they are both great engine platforms imo...
