Gold Digger »
https://forums.nicoclub.com/gold-digger-u15335.html
Mon Feb 08, 2010 4:33 am
Maybe on stock internals. You could build a pretty mean RB20 with some good bottom end parts, head work, bigger turbo and fuel system, and probably still not spend as much to get there as you would with an RB26 or a 1JZ.
The 26 can make stupid power, as does the 1J, quite easily, but it costs more money as the parts for the RB are more expensive. Plus scoring the engine itself is going to be costly.
Figure on stock RB20 bottom end, with upgraded fuel system, larger turbo, FMIC, full turbo back exhaust and decent computer tune, you could get close to 400.
Now, toss in some forged pistons with a slightly higher comp ratio (not to much higher), a head that has been machined properly, cams with gears to adjust timing...you're gonna be sitting nicely around the 500 mark. And 500 is a lot of ponies.
But, as I have said before, if you're drifting, you really don't need all that much power.
Hell, most AE86's barely break the 200hp mark and look at how well they do in pro circuits.
