I'll do that. Thank again EH?eh? wrote:Sometimes it's easier to see if it's in the middle by removing one of the bolts (engine off). Make sure the bolt hole is in the middle of travel. Then take a timing gun to make sure it's at 15.
So with engine ON w/o vac supply? What about with engine ON and vac is supply and w/o accelerate? Mine run 31PSI with engine on w/ vac supply and no idle accelerate and w/ accelerate it run about 35-40psi. it that correct. Thnk alotwawazat8402 wrote:43psi with the vac supply removed from the FPR.
Eh? I did chang the position of the timming several time and tow days in a roll i keep check the timing when engine is warn still 15*. So spark plug temperature does matter ok. Now what if it was MECHANICAL TIMING what I should do? Do i have take out the timing to adjust that?What if i leave @ 15* w/ bolt almost to the right, what can it cause to the motor?eh? wrote:If it's at 15 when the bolt is all the way to the right try switching the position of the timing light pickup or make a temp spark plug lead to get an accurate reading. If it is still at 15, try checking the mechanical timing.
Stick it back in the middle to be safe. Are you pulling the TPS when you are checking?To check mechanical timing download the fsm. Basically pull the upper timing belt cover and check to see if the cam gears and crank pulley all align.BlackRB wrote:
Got it. But the FSM for rb saying that we need to the CONSULT to do the timing. It there anyway we can with out the consult?eh? wrote:
So just disconnect the TPS (@600RPM) and use the timing light to check and set the timing to 15* and connect the PTS back on? And whatever degree the timing hit after the PTS connect back on, that is the degree is shold be. So normally w/o diconnect the PTS the timing will not be @ 15* correct?S14-NEO wrote:you dont need consult at all for the timing...thats only if you dont have a timing light, you can use consult's display screen to check timing without have to tap into the coilpacks etc. but you can use a timing light and get the same results .
