RB25DET NEO Help w/ CAM GEAR removal
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
I honestly have searched for hours (plus getting stuck reading build threads doing said searching haha) for how to remove the INTAKE CAM GEAR specifically. There is an allen/hex in the middle of it I don't have the right size for it and dont want to buy it not knowing it I can get it of like that. I read someone saying you can't removing it like that either.
I called Raw Brokerage and he asked me to email them (which I did) so figure I'd throw it out there and see if I can find an answer.
Thanks Tim
TimTurboZ
PIC
StricNyne
try r34 fsm
TimTurboZ
Any links u may know of, all I find is the R34 WSM (workshop manual) which does not contain engine tear down procedures...Thanks for any help you guys can give, feel lame waiting to do this b4 I take my motor into the shop lol
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
You'll take off your intake side valve cover and hold the cam shaft in place with a wrench... you'll see the casting where it'll accept a open end wrench.
Take a hex socket to the front of the cam gear and remove the front most plate. After that you'll find a washer, spring, o-ring behind it (remove these).
Then remove the single bolt in the center of the cam gear that hold the gear to the cam shaft.
Pull off cam gear.
Hope that helps.
TimTurboZ
THANKS! Will have to go buy the right sized hex asap
TimTurboZ
easy job, on my motor the front plate , washer and spring did not need to be removed 8mm on front 10mm for the cam bolt
TimTurboZ
Can mods delete this thread it was too simple lol I feel like a noob for not just trying 1st,just read ppl had issues with it
ruthlessone3k
Car: 95' r33 gts25t
dont feel too bad it helped me out too
TimTurboZ
Coolwhip wrote:After that you'll find a washer, spring, o-ring behind it (remove these).
Not required on RB25DETNEO both motors it was the front cover and center bolt, nothing had to be removed, so pll know
