RB25DET Motor swap finish in my Frontier HELP!
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
SkylineFrontier
Car: 2002 Nissan Frontier w/RB25DET motor swap
:ohno:
I'm trying to finish up my wiring for my harness and I'm inside the can and need to figure out what wires I need to tap into on my ignition. There are 6 leads on my ignition cylinder and I'm uncertain which wires will get pinned to it. On the cylinder I have battery (white/Red stripe), ignition 1 (black/white), ignition 2 (red), R (black/green stripe), ACC blue, and ST (black/yellow stripe). Any idea which of these I will use with that part of the internal harness? There is ignition + and ignition start signal on my harness. There is also a reverse lead on my internal harness which I'm guessing goes to the R (black w/green stripe) pin. Thanks guys and gals... I'm super close to getting this motor fired and just need a little bit of help. Maybe someone has a diagram. My truck is a 2002 Frontier with an RB25DET Neo swap.
Jason
Return to “GTR Forum / Skyline Forum”
