zman07 wrote:ok so i got my old motor out and im a little stuck trying to figure out the motor brackets. the only thing that is holding me back. does anyone have any ideas or know if the 240sk motor brackets for an rb conversion would work for my 87 300zx. or does anyone have any blue prints of the engine brackets for this swap?
I dont know if you read my swap... But it was really east to make the mounts the way I did them. It was a simple plate with one hole for the engine isolaters.
If I were to do it again, I would make the engine brackets, instead of modifying the factory n/a crossmember. It would look a lot cleaner, that is the only reason though.
From what I know the only interchange for the rb into a Z31 is the 200zr crossmember, I dont beleive that the 240sx crossmember will work, or the engine isolators. The skyline crossmember will not work in a Z31 also. I had one, I tried but the suspension geometry was completely different.
