rb25det missing
speed king
my rb25 started missing at first it was terrible no power wat so ever car sounded like a subaru den after a while it started to idle smoother but still wit sum missing can anyone shed sum light need help!!!!!
StricNyne
maf... at first u thought someone stole it
Shocker
Car: 89 240sxHB rb26/30
StricNyne wrote:maf... at first u thought someone stole it
lmao. same.
rotorimp
Car: 02 Xterra, 60 IH Metro
Don't rule out bad coil pack or injector--
What a nissan with a bad injector???--hope car gets found
DJButton
Car: 2010 Nissan 240sx
Oh noess, I'll help find it if I get a finders fee! On a more serious note there could be more then one thing wrong with it so a checklist of what's been done so far would help.
zdrifter
Car: 1978 Datsun 280z
Same exact thing happened to me...Check all your wiring, your ignitor might be going out and if that goes so does your ECU. The guy that helped me wire my car said he knew what he was doing but hooked up power to ground and grounds to power, fried my ignitor and ecu the day before a 2,000 miles trip to college and $1200 shop bill later. Dont mean to scare you but I wouldnt drive it anymore until you get the problem located, could be deadly
speed king
i opened it up changed the plugs the old plugs were pink in colur a sort of bright pink ???? still was missing one of my injectors was bad changed it an it's idleing smoother now but to me iam still hearing an slight miss like dup dup dup bout 4 times then it smoothens also the power light in the car (c33 medalist btw) flashes i think its 16 times when i start its my first 25 so all help greatly appreciated
speed king
anybody?
Carl H
behold the power of bad grammar.its hard to follow the problem here...what series motor is this?have you pulled codes?what does base timing look like?
