RBSilvia wrote:Did you ever figure this out? I've got a very similar problem with my S2 RB25.
Code 21, rough idle, cyl # 5 isn't working even though it's getting spark and fuel...
let me know
It recently went away after a nice rev till like 7k rpm, I had to put some ricer in an integra in his place.
I never had a cylinder not firing or anything like that though, in the beginning i had a leaking injector and one of the cylinders was flooding in fuel. the rubber o-ring was bad. i changed it thinking it went away but the same thing was still happening except for the rough idle.
In my case i think it was clogged injectors and some wiring that gives power to the fuel pump.
the very first thing i did was, i got a Aeromotive fuel pressure regulator with gauge. Set the right fuel pressure and the problem was still there.
Then i checked the voltage going to the fuel pump and found out that it was only 4v on idle, so i just installed a relay so it has 12v constant when the ignition is on, the regulator would do its job no matter how much fuel goes in.
Later on I put some Chevron fuel injector cleaner when i had only like a 1/4 tank of fuel (i put the whole bottle that is supposed to be for 20 gallons) so its was more concentrated and then went through like 1.5 tanks of fuel, After like a week one time a dude in integra pulled up and was thinking he was all that, all he had was body kits and intake prob. So i revved my motor till like 7k, since the misfire would only happen on load. After i revved it the problem almost went away, it would still be there sometimes though. so the next day i put some more and it basically went away.
You should take off your fuel rail with injectors, and have some one crank the car while you have the injectors in sight to see if they all spray the same.
It can also be that the ecu is not getting enough current from the battery and the alternator, i have my battery relocated to the trunk and a thick 4 gauge cable running all the way to the front, then that cable is joined with the starter wire, the alternator and the chassis. They are connected with a big bolt from home depot that tightens and is made for wires. I really dont like that idea but thats all i can do for now, i will solder them all when i have to take off the intake manifold.
The reason im saying this is because i think it could be a solution. one day i noticed that my battery wasnt charging so i measured the alternator output voltage and it was 14v so i knew that it was that link with the bolt that failed.
So make sure you get a good contact from the battery to the chassis and the alternator... also check the alternator terminal and sand it with some sand paper for good contact.
code 21 is still there and never goes away, i reset the ecu and it goes away and then comes back, but it souldnt be a problem because my car runs good now i just have some overheating problems after driving for a while and after accelerating a few times when its hot outside. Maybe you can help me with that.
Hope this helps, keep me posted. i would really like to know if this solves the problem
