I'll start on things that need answers. (using std S13 dash)TachoSpeedoFansDash lights (check engine, oil pressure)Throttle switch (NOT TPS - its a low/high switch)
The above is a start on whats required, and thats not including the engine sensors etc that are no used on the '8 step to startup' thread.Basically, try and get together a FULL set buy step to the install.
Can we try ot keep this on topic and as a reference. No speculation as to what you 'think' it is
