i purchased the syko kit w/ driveshaft thru phase2motortrend.com. i received it within a week or so from them. so far, i haven't had any problems with the kit. it was very easy to install and drop the motor in. it sits the motor perfectly in the car. i also have yet to drive the car too so i'm not sure how they perform under a load and whatnot. so we'll see when that day comes in the next couple weeks or so.
you'll also want a different radiator and some fans, probably flex-a-lites. don't use the s13 rad because i've heard that its too weak to handle the pressure of an rb. (i've never experienced this, just heard from other people about it) so i have an s14 rad that will work. if you get an aftermarket one like koyo or something, you'll prolly have to notch out the rad support and stuff.
as for the intercooler kit, i went to rb-performance.net....they have a specific intercooler kit thats a direct bolt on for the rb25 in an s13. it has the hot and cold pipes on the same side to accomodate the stock intake manifold. and its only like 300 for the full kit. thats what i'm using on mine until i can afford to get a new intake mani, which then, i'll get a new intercooler and piping. it was kind of a pain in the a** trying to get ahold of this guy for the intercooler and the shipping for it, but he took some money off of the purchase, so it wasn't too bad. heres the link for the kit.
http://www.rb-performance.net/....aspx
just like mrose7716 said...if you get the syko kit, make sure you get the R33 crossmember. also make sure you get either the R33 transmission crossmember OR an automatic 240 transmission crossmember. the manual transmission one will not work with it. the syko kit comes with transmission relocation brackets that use the r33 or the auto 240 transmission crossmembers.
also keep in mind that you'll have to get the wiring harness done too. i don't know how good you are with wiring and electrical stuff. if you aren't that great at it, i would suggest sending it out to somebody that knows exactly what they are doing.
heres a little list off the top of my head for what i had to get for my swap becides the motorset:
syko mount kitsyko driveshaftR33 crossmember and transmission crossmemberS14 RadiatorSamco coolant hosesFAL dual puller fansSR20 downpipe (i went with megan racing)Test pipeCatback exhaust (i got apexi gt spec)FMIC (from rb-performance.net)wiring harness conversion
thats just off the top of my head to get it in the car and running. you'll also want to look at doing other maintenance type stuff like:
timing beltidler pulleytensioner pulleynew hoses and vacuum linesspark plugsgaskets (if you wanna pull the motor apart)thermostatnew clutch
and also any other little stuff you might run into during the swap.
not trying to push you away from this swap or anything. you just gotta know what you'll be getting yourself into and how much money will be spent on it.
good luck with it. just like nissan2367 said....don't skimp out. do everything right now, so you won't pay for it later.
